The file below contains a quick start guide for the Dynamics Coupling Interface :
– Quick Start Guide :
This guide includes an example of how to setup a project in Microsoft Visual Studio, using the Free Body example available in the forum.
You will find out how to :
1 – Create a new empty project for creation of a console application.
2 – Include the appropriate directories and libraries
3 – Run a coupled simulation between EDEM and the FreeBody.exe (code control dynamics)
