This tutorial describes how to create 1-way coupled particle-fluid model using a Particle Body Force API.
The main focus is on:
- Familiarization with Microsoft Visual Studio 2019
- Importing existing Particle Body Force source code and header files
- Modifying and compiling the source code
- Importing Field Data via the Field Data Manager
- Loading a compiled model into EDEM
- Updating GPU source code (advanced)
