In MotionView, model parameterization is a strength that enables users to build functionality into their models that makes setup and updating model parameters easier.
It’s been observed that some users are utilizing Solver Variables to hold static values in their models, when it would be more appropriate to use Data Sets.
This document will explain the advantages of both Solver Variables and Data Sets, and when it would be appropriate to use one vs. the other.
