In this article you will learn how to choose the right solver and mesh size for EM simulations.
1 – Remote Keyless Entry.
2 – 315 MHz for US market & 434 MHz for Europe.
3 – Example of Coarse/Medium/Fine mesh related to λ.
4 – MLFMM solves quicker using uniform mesh size (Less mesh transitions preferred).
5 – Uniform mesh/Feature capture/Seats consideration dictates mesh size
6 – When using CADFEKO for Antenna and HyperMesh/SimLab for Vehicle modeling, the interface between Antenna and the Roof must be aligned external tools like HyperMesh/SimLab.
7 – Parametric CAD changes can be made using Parasolid Geometry Engine inside Altair Inspire
** - Indicates approximate memory size requirements for Antenna and Full Vehicle in a single simulation.
