To limit how many jobs can be run and retraced at any given moment, use the following command:
set config(maxNormalClients) NNN
This is the maxNormalClients config variable in the policy.tcl file.
To change the variable, use the following command:
% vovsh -x 'vtk_server_config "maxNormalClients" maxnumberofjobs'
To avoid exhaustion and possible denial-of-service, take into account the number of file descriptors available to the vovserver .
