To enable NC jobs to display on the submit host's screen, perform the following steps:
- Execute xhost + on the submit host. This will permit remote clients to connect.
- Use the 'ps' command. The X-windows server on the submit host must accept TCP client connections. It is not started with the -nolisten TCP option. For example:
% ps auxww | grep 'X'
This will enable you to see the X-server options.
- If the nolisten option is present, use the gdmsetup or equivalent command, so that X-server permits incoming client TCP connections.
