If a given license checkout is not showing up in your checkout history report, it could be due to the timing of the sampling period. By default, LicenseMonitor uses a sampling period of 30 seconds to check the status of each license. To detect license checkouts less than 30 seconds, you need to change the sampling period.
Note: You need admin permission to perform this task.
To change the sampling period, perform the following steps:
Note: Reducing the sampling rate can significantly increase the load on your LicenseMonitor instance. We do not recommend setting the refresh rate below 10 seconds, without close monitoring of the system response following the configuration change. This is especially true for installations with a large number of license servers being monitored. If you still need a faster sampling rate, more parsing resources may need to be configured. Please contact Runtime support.
That said, you can reduce the sampling period for all License Monitor Instances using the Command Line Interface.
To do so, perform the following steps:
vovproject enable licmon
cd `vovserverdir -p vovlmd
For Windows Installations, enter the following commands:
cd /path/shown/above
Set VOVLM(refresh) 30
