User Security Level |
Description |
Read Only |
Minimum privileges; a user can only browse the information but cannot change anything |
User |
A user can only execute established flows and view non critical information. In particular, a user can:
- Create, modify or forget his own jobs
- Create, modify or forget his own files
- Create, modify or forget his own set
- Modify or forget dependencies
- Create/modify/start/stop/forget own slave
- Remember jobs owned by other users
Leader |
A leader can create and execute arbitrary flows and view all non-security related information. In particular, a leader can:
- Start or stop his own slaves
- Forget all jobs, including jobs owned by another user
- Save trace database to disk
Note: This level is rarely used |
Admin |
An admin has access to most security information. In particular, an admin can:
- Forget jobs owned by other users
- Stop jobs owned by other users (no user can modify another user's jobs)
- Stop the server
- Stop/modify/forget the slaves
- Refresh slave cache
- Destroy a user
- Destroy a host
- Create or destroy alerts
- Create, modify or destroy resource map
- Reserve resource
- Create, modify or destroy preemption rule
- Create, modify or destroy multiqueue objects (LM sites, NC queues, resources)
- Create, modify or destroy LM objects (licdaemons, features)
