SimLab Tutorial: Steady Flow in a Centrifugal Blower
Learn how to:
- Create a tetra mesh with CFD boundary layer
- Work with moving reference frame
- Define CFD boundary conditions based on turbulence viscosity ratio
- Edit the solver settings
- Run and post-process the analysis
