SimLab Tutorial: Modal Frequency Response Analysis of a Crank Shaft
Learn how to:
- Create a modal frequency response analysis in the solution browser
- Define an excitation load based on applied loads
- Create a table with modal damping values
- Define the solution settings and output requests
- Compute solution and review results
- Plot and X Y graph for the displacements versus frequency
