Presentation by Ilya Tolchinsky, Phoenix Integration.
Phoenix Integration is a recently added member of the Altair Partner Alliance. Its product ModelCenter can create complex, fully automated simulation workflows and link these against Model Based Systems Engineering (MBSE) models. These typically descriptive models can now include accurate prediction of the system performance. This means that the status of the system requirements can be verified early in the product design cycle helping to avoid costly mistakes. Using ModelCenter the systems engineer can explore the possible design options and choose a configuration that represents best value while meeting its requirements. This paper explores this way of working by using an example built around an Activate Anti-lock Braking System (ABS) model. The example includes a SysML model built in Cameo Systems Modeler. It is connected to a number of analyses that evaluate the performance of a braking system. The paper illustrates the details of the architecture for this integration. ModelCenter design exploration techniques are then used to find the optimal configuration.
