Presentation by Professor Darrel Socie, Consultant.
Two case studies are presented to show the level of Analysis needed to solve the Fatigue problem. In the first case, the analysis could be carried out with a simple spreadsheet. The second case study involves a high value, large structure that demands a comprehensive analysis.
