Once the spatial curve has been displayed, you have to use the following procedure:
1 | Display the python command of the spatial curve in order to get the correct syntax
2 | In the command window, type: print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].values
Additional commands related to the post processing of spatial curve values:
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].meanValues
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].rectifiedMeanValues
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].rmsValues
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].minimalValues
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].maximalValues
- print CurveSpatial2D['SPATIALCURVE_NAME'].y[0].formula
