In order to use mapped mesh generator on faces with more than 4 edges, it is necessary to assimilate this face to a rectangle, i.e. structure the face by grouping the lines. To structure a face consists in choosing 4 vertex points to delimit 4 groups of lines (4 sides of the reference rectangle).
1 | Activate the Structure mesh / Structure faces for mapped mesh command |
2 | Fill out the dialog box:
