There are two ways to consider the Joule losses in the magnets.
- By using solid conductor region - circuit: In this case, there should be a solid conductor component in the circuit in series with a big resistor 1E4 Ohm.
- By using solid conductor region - non circuit: In this case, one have to choose "open circuit" option.
