Flux allows modelling two types of anisotropy: the crystalline anisotropy related to the manufacturing procedure; and the pseudo-anisotropy linked to lamination.
The pseudo-anisotropy is modelled in Flux by the homogenization of a package of stacked sheet metal.
Since Flux version 11.2, the lamination is modelled using:
You can find detailed information about the creation and the use of laminated materials in the following document:
