The Out of Core (OOC) mode is recommended when the calculation slows down; it means when a project use in the same time the swap file and RAM memory.
In order to set up this option you have to follow the next steps:
1 | From the Solving menu edit the Solving process options and go in the tab MUMPS |
2 | Click on Defined by the user |
3 | In the “Using disk memory” field set “Yes” Note: by default the option “Automatic-switch over the Out-of-core depending of the matrix size” is set |
4 | Click on Ok |
