Yes, it does. Since Flux v.10.4.1 it is possible to benefit of multi-cores processor with Flux in order to perform parallel computing. This functionality is activated by default with default setting (number of cores used).
In order to modify the number of cores used by Flux, the user has to follow the next steps:
1 |
2 | Click on Apply to validate your choice. |
