In this article you will learn how to reset single-user database passwords and restore access to the existing database.
The VOV Postgres database is used with Monitor and Accelerator, and uses three roles (user accounts) in normal operation:
The passwords for these roles are saved in properties on object 1 in the vovserver. These are established as random 16-character strings when the database is first initialized.
A new set of passwords will be generated when you use the 'Edit Location' button of the Admin->Database page. This initializes a new, empty database, and causes the passwords saved in vovserver to differ from the ones in the database, so the existing database becomes inaccessible.
+ get shell as LM owner on DB host, with Altair cmds in PATH
% vovproject enable db-project
% vovdb_util showcfg
(make note of data directory path; if you initialized a new DB, you may have to look up the path the previous location)
% vovdb_util stopdb -v
(stop the database from running)
% ps -aef | grep postgres
(Important: verify that postgres is stopped)
% vovprop list 1 | grep SQL_PW
Save the output in a file for reference
% ves +PG (add RTDA postgres cmds to PATH)
% postgres --single -D path-from-above rtda
('rtda' is the name of the database, starts db single-user mode)
backend> alter role rtdasu with password 'pw-from-above'
(repeat for 'rtdausr' and 'rtdamgr' roles, careful to match role/pwd)
backend> ^D (or your EOF char, if different)
% vovslavemgr show
(make sure vovdbd vovslave is running, start it if not)
% vovdaemonmgr show
(make sure vovdbd *daemon* is running, start it if not)
% vovdb_util startdb -v
(database should start normally)
