Using SmartCtrl to Design Outer Voltage Loop of a Buck
Using PSIM and SmartCtrl this video looks at designing the outer voltage loop of a buck regulator. This is a continuation of a previous video where we designed the inner current loop already. A PI controller will be implemented.
