This is the quick start guide for PSIM's InstaSPIN DRV8305 companion simulation with the F28069M launchpad: Learn to quickly generate the code and flash the MCU to implement sensorless control of a PMSM. Other videos will cover the different aspects of the simulation in more detail. This video will help you get the motor spinning as quickly as possible using PSIM's embedded code generation. Launchpad XL links:
