Option |
Description |
Example |
STATIS |
Statistical results are output in addition to regular output at each timestep. |
DISPLACEMENT(STATIS) = ALL |
OSTATIS |
Only Statistical results are output. |
DISPLACEMENT(OSTATIS) = ALL |
To View Statistical outputs in HyperView, Scroll to ‘Statistics Over Time’.
Transient Statistics Output Requests Available:
Output request |
Result Type |
Statistical Results available |
CSTRESS |
1.von Mises Stress (available in the individual plies)
2.Principal Stress
3.Normal stresses (Composite Stresses) in material/ply coordinate system
1.Maximum, Time of Maximum
2.Maximum/Minimum/Absolute Maximum, Time of Maximum/Minimum/Absolute Maximum
3.Maximum/Minimum/Absolute Maximum, Time of Maximum/Minimum/Absolute Maximum, Mean, RMS, Variance, Standard Deviation.
SPCF |
1.Magnitude
2.For X, Y and Z components
2.Maximum/Minimum/Absolute Maximum, Time of Maximum/Minimum/Absolute Maximum.
ACCELERATION |
1.Magnitude
ELFORCE |
1.Magnitude
DISPLACEMENT |
1.Magnitude
For frequency response analysis, STATIS/OSTATIS options are not supported yet in 2021.2 version. However, PEAKOUT can be used to select the criteria for automatic identification of loading frequencies at which result peaks occur. Output result output may then be requested at these "peak" loading frequencies.
