Overview
This macro intents to rename property with the component name, whether the property is assigned to the component or the elements.
Pre-Requisite
See the video below for the explanation of the code:
Usage/Installation Instructions
use File -> Load -> Tcl script to execute the macro or use Extensions to register it through a drop-down menu, a custom ribbon or a custom toolbar
