Overview
One user received a model with one single property defined tofor multiple components, and he wanted to assign instead one property per component.
I authored the attached script to answer his request.
Please look at the Youtube video below to review the automation strategy I used for authoring this script:
https://www.youtube.com/watch?v=-QkM8hI1vYk&list=PLGNemB0NFb0AXOgj3rPq929yZwXHQK63-&index=1
Usage/Installation Instructions
For running it, you can either:
- drag and drop the macro in the interface
- go to File drop down menu -> Load -> Script (*.tcl, *.tbc)
- create extensions: https://community.altair.com/community?id=community_blog&sys_id=0c38fa1fdb7401d0cfd5f6a4e296198f
